Visitor nymphaeae
How to boot an application that was stored on DDR from flash memory
Hi.
I want to know how to solve the following problem.
Board: VC707
Goal: Boot application(hello world) that was copied from flash memory by bootloader on DDR3 SDRAM.
Problem: SREC Bootloader should be working properly. However, Hello World application does not run…
The following sentence is information sent by UART serial.
-> SREC Bootloader
-> Loading SREC image from flash @ address: 60500000
-> Bootloader: Processed (0x)000001d4 S-records
-> Executing program starting at address: 00000000
System:MicroBlaze, AXI_EMC, AXI_UARTLITE, MIG_7_SERIES
Status:
  • I created SREC Bootloader application from SDK template.
  • I also created Hello World application from SDK template.
  • SREC Bootloader App links to BRAM of microblaze by “Generate linker script”.
  • Hello World App links to DDR3 SDRAM by “Generate linker script”.
  • FLASH_IMAGE_BASEADDR (XPAR_EMC_0_S_AXI_MEM0_BASEADDR + 0x00500000) in bloconfig.h
  • The download.bit including bootloader on BRAM of microblaze was generated by “Program FPGA”.
  • I programed Hello World App using “Program Flash”. (offset=0x00500000, and I checked “Convert ELF to bootloadable SREC format and program”, “Blank check after erase”, “Verify after flash”).
  • I programed SREC Bootloaer App using “Program Flash”. (offset=0x0, and I checked “Blank check after erase”, “Verify after flash”).
Are there any hints or advice?
