How to extract merits of Dynamic Phase Shift Interface and MMCM dynamic reconfiguration?
Hi everyone,
I am using Dynamic Phase Shift Interface and MMCM dynamic reconfiguration methods through DRP(Dynamic Reconfiguration Port) together to achieve a phase shift resolution of (1/56)th of the VCO time period(T_VCO) using dynamic phase shift interface and independant control on output clocks using the other method.
However there are limitations
1)Using the former, I will have a common control of output clocks with phase shift resolution of (1/56)T_VCO.
2)Using the latter, I will have independent control of output clocks with phase shift resolution of (1/8)T_VCO
Is there a way to have independent control of output clocks along with phase resolution of (1/56)T_VCO?
Thanks in advance
-Chandrasekhar DVS
Re: How to extract merits of Dynamic Phase Shift Interface and MMCM dynamic reconfiguration?
Hi @krishnachandrasekhar100
As you know the attribute CLKOUT[0:6]_USE_FINE_PS  select the output clocks to be dynamically phase shifted. The dynamic phase shift amount is common to all the output clocks selected , there is no way to have independent control of output clocks with fine phase shift resolution.
Additionally the Application note XAPP888 pointed out by @csattar does not support outputs configured with fine-phase shifting enabled.
hi @krishnachandrasekhar100 ,
can you please once cross check with following xapp
https://www.xilinx.com/support/documentation/application_notes/xapp888_7Series_DynamicRecon.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp878.pdf
chandra
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
