Visitor leopold2019
Kintex-7 output differential clock is weak
I use FPGA output a pair differential clock, The output differential clock is from a single end one that is one of output clock of MMCM.
I found that the frequary of output differential clock is correct,but the swing is small.
the IO standard of output clock is DIFF_HSTL_II_18.
What causes this problem?
Regards.
Re: Kintex-7 output differential clock is weak
j@leopold2019
You will find electrical characteristics for DIFF_HSTL_II_18 in the datasheet, DS182, for the Kintex-7.
https://www.xilinx.com/support/documentation/data_sheets/ds182_Kintex_7_Data_Sheet.pdf
The DIFF_HSTL_II_18 standard is available in both HP and HR banks of the Kintex-7 and outputs are current limited to 16mA, per Table 11 in DS182.
Please read UG471 about proper termination for DIFF_HSTL_II_18 since improper termination can reduce output swing.  Also, check input impedance setting for your oscilloscope since it can cause improper termination for DIFF_HSTL_II_18.
https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
Mark
j@leopold2019
Mark
