Master Constraints File for xc7vx980t
Could anyone help me to get the Master Constraints File (XDC Listing) for xc7vx980t FPGA device.
Community Manager
Community Manager
Re: Master Constraints File for xc7vx980t
The Master XDC for the VC707 is specifically for that board and what is populated and connected to the FPGA on that board.
The generic list of Pin is in the ASCII file link I sent you previsouly. Say you are using a FFG1926 package the file is :  https://www.xilinx.com/support/packagefiles/v7packages/xc7vx980tffg1926pkg.txt
Then you can see in the Packaging Guide Table 1-12 the description of the functionality of the pins :
http://www.xilinx.com/support/documentation/user_guides/ug475_7Series_Pkg_Pinout.pdf
For example there are two types of Clock inputs MRCC (multi region clock capable) and SRCC (single region clock capable). If you look in the ASCII file then you can see the IOs that are MRCC or SRCC.
Community Manager
Community Manager
I'm not sure what a Master Constraints file is. The demo boards have Master Constraint files but that is with the specific pinout for the board.
If you want the ASCII file that lists the pins and their functionality you can find them (for each package) here:
https://www.xilinx.com/support/package-pinout-files/virtex-7-pkgs.html
I want to know the clock and I/O pins for the xc7vx980t device.
Something like the list in VC707 Evaluation Board for the Virtex-7 FPGA User Guide.
For example, xc7vx485t has the pins E18 and E19 for the system clock.
Community Manager
Community Manager
Thank you.
That helped me.
But, what is the difference between using MRCC and SRCC?
Community Manager
Community Manager
@elsayed.abdellah
MRCC -> Multi-region clock-capable I/O
SRCC -> Single-region clock-capable I/O
Take a look at Table 1-1 from Page#24 of UG472 which has more details.
- Giri
