Visitor ammar_0697
RS-232 Communication via Virtex-5 LX50T FPGA
I am trying to send data from Virtex-5 FPGA LX50T 1156-pin board to PC using UART RS-232 protocol. Software  I am using is XIlinx ISE Suite and language is VHDL. But the code is not working. Files are attached.
Kindly help me
Re: RS-232 Communication via Virtex-5 LX50T FPGA
hi @ammar_0697,
we do not suggest or work on the RTL level  of user code , if you have any error messages or any queries with respect technical details of the  URAT interface  with FPGA  please post them here
chandra
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Visitor ammar_0697
sorry but i dont know what is rtl level. I am new to fpga and vhdl plz guide me
hi @ammar_0697,
In digital circuit design, register-transfer level (RTL) is a design abstraction which models a synchronous digital circuit in terms of the flow of digital signals (data) between hardware registers, and the logical operations performed on those signals.
Register-transfer-level abstraction is used in hardware description languages (HDLs) like Verilog and VHDL to create high-level representations of a circuit, from which lower-level representations and ultimately actual wiring can be derived. Design at the RTL level is typical practice in modern digital design.[1]
Chandra sekhar
hi @ammar_0697.
To be more speific we do not support at VHDL or VERILOG coding .
Chandra sekhar
