Visitor parampampam
Receiving 1080p 60 Hz DVI video with Artix-7
Can Artix-7 be used for receiving 1080p 60 Hz video (165 MHz pixel clock)? It supports Peak Transceiver Speed 6.6 Gb/s. It should be enough for this purpose, but I'm not exactly sure.
Regards.
Re: Receiving 1080p 60 Hz DVI video with Artix-7
You can refer device switching characteristic guide.
http://www.xilinx.com/support/documentation/data_sheets/ds181_Artix_7_Data_Sheet.pdf
Thanks and Regards
Balkrishan
Visitor parampampam
What is about logic primitives for DVI/HDMI in Artix-7? There is great pdf describing receiving/transmitting TMDS on Spartan-6: http://www.xilinx.com/support/documentation/application_notes/xapp495_S6TMDS_Video_Interface.pdf Is there something like that for 7 Series?
