Visitor ariahsz
Route Error (471) ISE 14.2
Hi everyone!
I have problem with route error 471 and I am using VC707 board.
I cannot solve it.
Re: Route Error (471) ISE 14.2
@ariahsz
I had a look at the design. When I ran autoroute -all in FPGA editor, I encountered below error.
ERROR:Route:471 -
This design is unrouteable. Router will not continue. To evaluate the problem please use fpga_editor. The nets listed below can not be routed:
Unrouteable Net:uut2/gmii_rxd<3>
Unrouteable Net:uut2/gmii_rxd<5>
Unrouteable Net:uut2/gmii_rxd<0>
Unrouteable Net:uut2/gmii_rxd<7>
Unrouteable Net:uut2/gmii_rxd<2>
Unrouteable Net:uut2/gmii_rx_er
Unrouteable Net:uut2/gmii_rx_dv
Unrouteable Net:uut2/gmii_rxd<4>
Unrouteable Net:uut2/gmii_rxd<6>
Unrouteable Net:uut2/gmii_rxd<1>
These nets are going from SLICE output to IDATAIN pin of IDELAYE2 element. Below is snapshot from net properties.
The IDATAIN pin of IDELAY element can be driven by its associated IO alone. In your case you are trying to connect this pin to slice which is resulting in route error. Please fix this in your design.
Deepika.
Deepika.
Check this http://www.xilinx.com/support/answers/20837.html
Open FPGA editor and examine the unrouted nets. If possible attach the test case (or .ncd and .pcf files) so that we can check the reason for failure.
Deepika.
Deepika.
You have not posted sufficient information to allow anyone to help you. You must include the entire ERROR message and your thoughts on why this may be occurring and what steps you have done to resolve the problem.
Visitor ariahsz
thanks alot!
here are the required files.
Visitor ariahsz
Please tell me how I can fix the problems with fpga editor.
Thanks !!!
Thanks for attaching the files. I will look in to the design and post here back.
Deepika.
Deepika.
Visitor ariahsz
thanks.
@ariahsz
ERROR:Route:471 -
Deepika.
Deepika.
Hi @ariahsz
Did you check this?
Deepika.
Deepika.
Visitor ariahsz
Hi vemulad
Thanks for help. I have modified the design according to your advice and it was helpful.
Now everything is OK!
Best Regards
Observer azizsh
hello all,
hello @ariahsz
I'm stuck in exactly the same problem with the same unroutable nets (gmii_rxd) and I'm getting the same error
How did you resolve the issue?
if u remember :)
Thanks in advance
regards,
Aziz
