Visitor f1t3
SelectIO Interface Wizard reset procedure / reset delay
PG070 states in Table 2-1 for the io_reset signal:
I/O reset: Reset connected to all other elements in the circuit. For proper functionality, io_reset has to be deasserted when the clocks
to SERDES are stable. Due to this requirement, io_reset must be deasserted after some cycles of clk_reset deassertion. For 8:1 serialization, sixteen cycles delay of I/O clock between clk_reset and io_reset can be used.
What is the most common/convenient way to achieve this 16 clock cycles delay? Attached is my current design, in which the data_out_to_pins stay dead. I suspect this is beacause of the wrong reset procedure, or am I totally wrong here?
Visitor f1t3
Re: SelectIO Interface Wizard reset procedure / reset delay
Never mind, a simple RAM-based shift register does the job.
Visitor f1t3
