Virtex-5 (XC5VFX130T) VCCINT supply current
Hi! I'm in the process of powering up my 8 pieces of XC5VFX130T boards.
1.0V for the VCCINT, 2.5V for the VCCAUX, and 3.3V for VCCO. The power supplies are turned on in the order recommended by the spec sheets. So VCCINT -> VCCAUX -> VCCO,and the ramp time is satisfied with ds202 table-6.
There is no bitstream load in XC5VFX130T under the test for temporary.
The test time of all these boards is very short, so I'm sure the temperature of the FPGA is not too high.
 In my design, there are small resistors(12 milliohm) connected in series to the power supply so I can measure its current.
Now I find the STATIC supply current of VCCINT is different from each other but stable.
board1: 0.625A
board2: 0.642A
board3: 0.733A
board4: 0.850A
board5: 0.883A
board6: 1.117A
board7: 1.125A
board8: 1.500A
Is this NORMAL? Are the current on board6-8 too high?
What is the relationship between this result and Table-4 and Table-5 of ds202?
 Thanks!
回复: Virtex-5 (XC5VFX130T) VCCINT supply current
Hi @peterxilinxok1
In Table 4/5, Iccint is specified @85C. On board 6~8, Tj may not be higher than board 1~5, please download xpe to estimate the static current @ other 85C of Tj.
http://www.xilinx.com/power
Simon
