Visitor @neha
chipscope problem
I used a BROM. I want to see it's output data at chipscope. but chipscope shows its last element only.
means I have a BRAOM of size 1200 data, where 1200th address contains data 255. then chipscope shows only data 255 and address 1200. it did not show data from 0 to 1200, which I want to see.
Another problem is BROM also have a reset signal. which i applied on hardware with a switch. Either I apply reset or not chipscope shows 255 and address 1200. but in simulation if reset is not applied then it does not show any data.
So, I want to ask where i mistaken.Please help me in this.
Re: chipscope problem
Hi @neha,
How you are accessing data from ROM? How you are connecting signals to chipscope?
It seems you have connected dout to probe in chipscope which is data of a particular address.
If possible share the code/project to have a look.
Arpan
Arpan
Visitor @neha
For a test I write a code which contains only dcm ip core, i used given code for that
module dcm_test(
input wire clk_p,clk_n,reset,
output wire clk1);
wire clk2;
wire locked;
dcm myclock
(// Clock in ports
.CLK_IN1_P(clk_p), // IN
.CLK_IN1_N(clk_n), // IN
// Clock out ports
.CLK_OUT1(clk1), // OUT 100 Mhz clk shown as a output on chipscope window
.CLK_OUT2(clk2), // OUT 200 Mhz clk apply as a chipscope clk
// Status and control signals
.RESET(reset),// IN
.LOCKED(locked)); // OUT
endmodule
Here also either i apply reset or not it shows clk1 on chipscope.
I also attached my project files
