"Hello world" not working on Zynq 7000
I am trying to run the "Hello world" program on my Zynq 7000 family board. The issue which is happening is i am not able to see the output of the program on my Terminal. I am using the SDK terminal for seeing the output. I have already gone through some videos from xilinx on SDK and i am following the same steps as they did. One day before, it was working fine but, i am really unable to figure out what is the issue now. I am a kind of a newbee in using Viavado and SDK, so it will be really great if some one can help me out.
I am using Vivado 2019.1.
So these are the steps which i am following:
1) Created a block diagram in Vivado and generated the bitstream. We can see that i am using UART1 and GPIO in peripherals.
2) Then I launched SDK from Viavdo and Created a new Application project. Then i used the "Hello world" template and created the BSP.
3) I created a "Run configuration", connected my terminal, Programmed my FPGA and then Launched the program on Hardware.Screenshot (2).png
Please let me know if any other information is needed.
Amol
Tags (2)
回复: "Hello world" not working on Zynq 7000
Hi amolb@iisc.ac.in ,
Perhaps you should create a debug configuration, then connect terminal. And you can see Hello world using Step Over(F6).
Or you can add a loop:
while(1){
     print("Hello World!\n\r");
Have a try and let me know if you still have problem.
For beginners, please follow ug940 Ch1 & Ch2.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I ran the part which you mailed me. But, still not working.
Thanks for the  ug940.
Amol
Please give me more deatails such as your board information.
Please check these:
1.ZYNQ core -> MIO Configuration -> IO Peripherals -> UART1(zc702 is MIO48/49)
Check board schamatic.
2.Device Management. Make sure COM6 is the target.
3.SDK -> test_bsp -> system.mss ->standalone
stdin and stdout should be ps7_uart_1
Thanks a lot it started working !!
I alotted the UART ports to MIO 48-49 and now it is working.
PS: I am using the Zybo Z7010.
