Observer micrelrogerlo
what's the maximum clock domain signal could be debugged in ila debug core?
     I am using xc7v2000tflg1925-2 FPGA device. I am just wondering if it would be okay to debug signals which are in 312.5 MHz clock domain by using ILA core. If yes, what would be the speed limit in ILA core?
Roger Lo
Re: what's the maximum clock domain signal could be debugged in ila debug core?
Hi @micrelrogerlo
You need to consider the Fmax of the device .(Fmax of the device is decided based on maximum supported frequency by global buffer (BUFG)
To debug/sample 312.5MHz signal in the ILA, the ILA should be run at min 625MHz accodring to sampling theorem.
as you are using -2 speed grade device, the Fmax of the device is 710Mhz, so it will not be any problem with your approach
Hi, @micrelrogerlo ,
There is no explicit speed limit for the ILA core.
If there is no timing violation after inserting the ILA core, it should work.
Hi @micrelrogerlo
Mentor hgleamon1
Mentor
Surely the ILA core should be clocked by the same 312.5 MHz clock that those signals marked for debug are clocked by?
"That which we must learn to do, we learn by doing." - Aristotle
Hi Hongh,
     Thanks for sharing your opinion.
Hi Hgleamon1,
    Thanks for your reminding.
Hi Pthakare,
    The information is very helpful. Thanks so much.
