7-Series PCIe Gen3 Max Payload Size
Dear Members,
I am developing a PCIe Gen3 application in 7-series FPGA (xc7vx690t-2ffg176) and found some inconsistency in the IP documentation
1. The product guide (pg023 v4.3 page 8) states that the IP is capable to support a Max Payload Size of up to 1024B.
2 .However, in the Completer Completion descriptor fields (pg023 v4.3 page 119), the DWord Count field is defined as
the size of the payload of the current packet in Dwords, and range between 0-1024 DWs, which is more than the Max Payload Size parameter state before.
3. Similarly, in the Requester Completion descriptor fields (pg023 v4.3 page 154), the DWord Count field is defined as
the size of the payload of the current packet in Dwords, and range between 0-1024 DWs, which again, is more than the Max Payload Size parameter state before.
So, basically, my question is what should be the right definition for these fields?
Thanks ahead!
Re: 7-Series PCIe Gen3 Max Payload Size
@nissan.luzon
It seems I was wrong. Max payload size is limited to 1024bytes.
The range specified in the sections you referred to as saying 1024Dwoards is based on the PCIe spec. The spec allows that a packet can be 1024Dwoards. It is not related to the supported max payload size with V7 Gen3 IP.
If you check Table B-1 on page 297 of PG023 v4.3, you can find Max Payload Size is limited to 1024 bytes.
Please check table 2-14, the max payload size with Virtex-7 gen3 IP is 4096bytes. We will fix the page 8 of PG023.
Hi venkata,
Thank you for your reply. I see now that table and that indeed correlates with the CC and RC description above.
However, if the MaxPayloadSize can optionally be set to 4096B, why I can't configure the Integrated Block GUI with such value? The maximum value presented in the GUI is 1024B, as can be shown in the screen shot below (captured from Vivado 2018.2, but is the same for older versions of the tool):
@nissan.luzon
OK, that’s seems to solve the issue.
I think Xilinx should update the sections mentioned such they describe the core capabilities rather than the PCIe spec.
Anyway, thank for your help!!
