Observer goli12
AXI-Memory Map to PCIe simulation
Hi everyone,
I was following the steps on page 85 of PG055 to simulate the AXI-Memory Map to PCIe core in root-port mode. I just want to confirm that If I need a physical board to do the simulations.  The simulated waveform is shown below. At the moment, It doesn't look right as I was expecting to see output log messages from board.v wrapper file. The last message I got in the log is: "Built simulation snapshot board_behav". axi_rc_waveform.PNG
goli12
Observer goli12
Re: AXI-Memory Map to PCIe simulation
Hi Venkata
Looks like my simulation passed from the output log. It looks like instead of just "run behavioral simulation", I needed to run "run -all" command to fully run the simulation.
Cheers for the help.
Andrew
Can you run the simulation for some more time? In the test bench, there should be some time out and you can find a message saying test bench timed out when it happens.
Observer goli12
Hi Venkata
I have attached the output log and the tcl console output when the simulation was running. There doesn't seem to be a time out. I should say that I am running on Vivado 2015.4.2.
Andrew
In the snapshot you showed, the serial lines have not started toggling. So I think GT has not completed initialization. I was asking to run the simulation longer so that you can find time out message in the simulation log.
The logs you have shared does not show the current status of the simulation.
If you are simulating IP example design, can you please share the .xci file of the IP?
Observer goli12
Hi Venkata
I will run the simulation using the run - all command and let it run all night. Looks like 1us was not enough time hence the serial lines weren't toggling. I will get back to you with an update once the simulation is complete.
Cheers
Observer goli12
Hi Venkata
Andrew
