Observer bmoore
DMA/Bridge subsys for PCIE in ZCU102?
Is there any equivalent for the DMA/Bridge subsys for PCIE IP that is offered for the Zynq US+ XCZU7EV, for the XCZU9EG that's on the ZCU102 dev board? There's a RTL PCIE block but it's not a complete solution. Is there any code out there that would give me the equivalent of that hard PCIE block that's in the 7EV? I wanted to test out a 7EV PCIE root design but I only have a ZCU102 dev board available.
回复: DMA/Bridge subsys for PCIE in ZCU102?
Do you want to use PCIE DMA with PS PCIE
Have you checked out http://www.wiki.xilinx.com/XAPP1289+PCIe+Root+DMA
Observer bmoore
Yes, I did. I need to implement the PCIe in the PL, not the PS, because I will be using the GTs in the PS fabric for other things. Also need the Gen 3 speed that the PL GTs offer. But thanks for responding.
XCZU9EG device does not have a PCIe hard block. I hope you know this already. You will need to check for soft PCIe IP solutions.
If you check PCIexpress IP web page on Xilinx website, you can find references to IP partners - Nortwestlogic and PLDA.
https://www.xilinx.com/products/technology/pci-express.html
