Visitor asi_ka
Hardcode power limit value for PCIe core
In the docs I can see that we can set the power limit value/scale in "device capabilities register" through the configuration interface. I was wondering if it's possible to hard code the value at synthesis time as a parameter to the module.
Re: Hardcode power limit value for PCIe core
With UltraScale+ PCIe IP, I can find that there are two signals that can help with your requirement --cfg_msg_transmit_type, cfg_msg_transmit_data.
Please check the description of these signals in PG213.
