Visitor captainjiang
PC cannot find the PCIE device?
I use the PCIE IP core v1.5.I have generate the .bit file and then download the file to the FPGA. But when I open my PC,PC can not find the PCIE device.I do not know why?I use the example design.I just modificate the .ucf file.I change the GTP.
after changing
INST "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i" LOC = GTP_DUAL_X0Y2;
default is
INST "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i" LOC = GTP_DUAL_X0Y4;
Is this the problem?
do I also need change others?
who help me?
I really need your help! please
thanks in advance.
Visitor ludwigvan
Re: PC cannot find the PCIE device?
Do you have correctly assigned reference clock and pci express reset pins on your ucf?
Why don't you use the latest PCI Express Endpointv 1.9 rev4?
You should however specify more precisely the FPGA and board model...
Ludovico
yes I assigned the correct reference clock and pci express reset pins .I have seen these signals working.
I have tired the core v1.9 and I have the same problem.
Can I get a conclusion that there is something wrong with the hardware.
Visitor ludwigvan
Excuse me if I insist, but have you tried with the Endpoint version 1.9.3 coming with EDK 10.1.03 or did you tried yet with the patched Endpoint version 1.9.4?
If not, please see AR #31532 at http://www.xilinx.com/support/answers/31532.htm, you can download such patch from there.
I'm telling you this because we had the your same problem and this patch fixed it.
I am sorry!I do not think it is a good idea.I am not famaliar with the EDK, I shuold study it from the begin.It is a hard work for me .I do nor have  enough time. I have a question.did you download the example design?how to set the IP core?I use the default settings in generating the core.I change nothing!should I change something!could you give me some advice?
Visitor ludwigvan
I'm sorry for my mistake... It has been a lapsus (I was working in EDK). The 1.9.4 Endpoint patch I was referring to is that of Core Generator, not EDK. You can safely apply that patch whitout knowing anything about EDK! In fact you only have to unzip a zip archive in the correct dir, then regenerate the core in Core Generator.
In answer to your questions, yes, I downloaded to my board the example design, and the default IP core settings are correct to work with the example design, you should change nothing.
thanks for your answers! I am using ISE9.2i and I have simulated the PCIE IP core! The version of IP core is V1.5.you mean that the version is so low that there is some bugs.I designed my board.I do not use the development board.you know that I change the .ucf,I am not sure this will affect my board or not.if not,I think the problem must be located in my hardware!
I want to know about your board.Is your board development board?My board is not!
I have tried the core v1.9.4 .the core can not be found by PC.I think the problem is located in link training!only the trn_lnk_up_n is deasserted!other signals is working well!
Visitor ludwigvan
My board too is custom designed...
did you change the place of the pins ? especially the pcie interface? GTP?
Visitor ludwigvan
Yes, I had to change GTX, clock pins and pci express hard ip block locations.
why I can not? My god!! thank you very very very much!!!
I have another question.did you connect your board to the PC's motherboard?
Visitor ludwigvan
Yes, of course. I was having your same issue (card not detected or PC stuck at boot) but, as I said, the last 1.9.4 Endpoint block patch fixed the issue.
I have tried but no effect!
