Visitor wgzhang
PCIe DMA C2H wrong on VCU118 REVC.2
I have used the DMA/Bridge Subsystem for PCI Express v3.1 on EK-U1-VCU118-G(REV2.0) for PCIe x1 lane. It works fine.
When I download the design to EK-U1-VCU118-G(REVC.2), the DMA channel C2H works wrong.
From the hw_ila waveform, it start DMA transfer for the first descriptor, then the C2H engine stop.
Reading channel status register, bit0 is 1, indicates the channel is busy. When I stop the channel by clear bit0 in the control register, the channel is still busy.
Who can tell is there any difference between xcvu9p-flga2104-2L-e and xcvu9p-flga2104-2L-es?
thank you.
It's OK. must use vivado2016.4 for xcvu9p-flga2104-2L-es1, not vivado2017.2.
Re: PCIe DMA C2H wrong on VCU118 REVC.2
XDMA has a port available called "dma_bridge_resetn", which is turned on via a parameter switch of CONFIG.soft_reset_en in the IP. This allows you to reset the bridge/DMA IP without resetting the full core.
On the failing board, can you try this?
Visitor wgzhang
Thank you! My problem is OK. must use vivado2016.4 for VCU118-ES1, can't vivado2017.2.
