PCIe board not working
I am trying to comminicate to FPGA and PC with PCIe interfacing.
Sytem- Spartan 6 PCIe board by NUMATO.
             Windows 10- 64 bit
-I am not getting interrupt req no(line no).
-It's not using any resources also.
What can be reason here?( attached pic's)
回复: PCIe board not working
it is the SW that write to this register
Are you able to write to 3c?
@liy  No, software is unable to write into interrupt register.
Only interrupt pin got written by ip core.
What should i do next?
Hi @liy
I checked on win 10- 32 bit mini version by USB stick.
It worked there, data transfer happened.
So my guess is it's driver problem, proper driver is not getting installed in win10-64 bit version and it's not showing any resources(MEM range and IRQ no here).
So where i'll get driver for Spartan 6 pcie win10 64 bit ?
I have a similar problem, with the BAR locaitons returning all FFs.  This occurs only on a Win10 machine.  Did you ever solve your issue?
@markzak
On win 10-64 bit- NO, problem's still there.
If you get anything, please update here.
Thanks!
