Visitor sharathm@535
PCIe card not getting detected
I'm Sharath.
I have an issue with respect to my Network Interface Card. The card gets detected and works completely fine in a PC which is having Gigabyte GA-X58A-UD5 motherboard and Windows 7 OS. When the same card is mounted on another new system having Gigabyte B360M D3H motherboard and Windows 10 OS, the card is not being detected at all. The LTSSM state machine was initially getting into a loop starting from Detect state to Configuration Lanenum Accept state and then go into the Timeout to Detect State. But now the LTSSM state machine gets stuck in the Polling Compliance state. I've tried debugging this issue using the document attached and also other answer records available in the Xilinx website since a few months, but not able to figure out the exact reason for this issue and find a solution to this problem. I request somebody to help me out with this. I'd be glad to provide any further information required to debug this issue.
Hope to get a reply soon!
Thanks and Regards,
Sharath
Re: PCIe card not getting detected
Hi bethe,
Sorry for the late reply.
The PCIe card got detected after disabling the power management settings in the PCIe IP Core.
Anyways, thank you so much for sharing your views in solving the problem.
Thanks and Regards
Sharath
Hi sharathm@535
Does your NIC card have a Xilinx part on it?  If so, which Xilinx part is it?  That will help quit a bit in breaking down the problem.
Well, I'm using Kintex-7 FPGA in my NIC. The part number is xc7k160tfbg676-2.
Hi sharathm@535,
There are 2 possibilities here:
1) The physical circuit for detect is not working - for this, please check the termination resistance at the fingers when the card is powered -- should be 50 ohm single ended or 100 ohm differential (as set by MGT_RREF).  Also ensure your TX coupling cap on the host side is present and correct.
2) (More Likely) - the FPGA isn't programmed by the time the host is coming through, and thus the link isn't getting trained.  The quick check for this one is to do a warm reboot (ensuring the FPGA doesn't lose power).   If the card is detected and trains - that is the issue.   There are some host systems that are strict on the requirement for the PCIe link to be available within 100ms of power.  Depending on your programming settings and image size, we may not meet that, and the result is what you are seeing.
Give these two a go - and let us know the results!
Well,the results for the two tests are as follows.
1. The physical circuit is being checked and verified to be correct. Moreover, if there was something wrong with the physical circuit how can the card get detected and work properly in the older system as mentioned in my main post? I hope you got my point. I'm just placing my queries here so that I could solve this problem and get a few more knowledge about this topic. Please don't mistake me.
2. Warm reboot also couldn't help the card to get detected by the system.
Hi sharathm@535,
Can you please provide the details on the host system you are using?  Also could you please ensure you are using 2017.3 or later?
The system details of the system in which in which the card is working and the new system in which the card is not even getting detected are attached.
Currently, I'm using Vivado 2017.2 for this particular project.
Hi sharathm@535,
Please try the following 2 tests:
1) Please upgrade the core to 2017.3 minimum, preferred 2018.1.
2) Could you create an example design using the 7-series Integrated Block for your card?  This will allow us to eliminate a number of variables.  Since at this point we are just trying to get through detect and training, this will help us narrow.
Hi bethe,
Thanks and Regards
Sharath
sharathm@535
You disable Power Management settings in Pcie IP core by under PME support uncheck D0,D1,D2,D3 and Nosoftreset?
Yes, exactly.
Observer sachinb_apt1
 I am using PCIE-XDMA IP, I dont find the power management settings. This VU9P with 2017.3
Hello Sachin,
Firstly, confirm if there's an option to change the power management settings in the core which you mentioned. You can go through the datasheet of that particular core.
Sharath
