Visitor yyyli
PCIe device not detected
I am using XDMA IP in the ip integrator , but after I created bitfile and programed the fpga ( XC7VX690TFFG1157-2),the device can not be recognized via lspci command
can anyone help me with the problem?
Below is my block design
PS: I have used the IP catalog and created the example design and the device can be detected.
回复: PCIe device not detected
Please verify if the pin assiment is the same as the example design.
also try a reboot
Visitor yyyli
Thanks for your reply!
But I found another question is that when I select Gen2(5.0Gb/s), there are timing violations.timing_violations.PNGAnd the Gen1 can run successfully.
How to solve this problem?
