Observer uncle_tim
Problems with pcie4_ucale_plus demo design
I am using the ultrascale PCIe core demo design, my bus width is 512 bit.
* As long as I don't attempt bus mastering, everything works fine. I can read and write from the card, everything is stable.
* When I activate the gen_transaction signal, it generates a read transaction and reads 1 DW from computer memory. That also works fine! I see the correct memory values appear on the ILA window.(rc_tdata)
* The trouble starts when I want to read more than 1 DW. As soon as I change the "DWORD Count" in the rq_tdata from 1 to anything else, for example 2 or 4, all hell breaks loose:
The signal user_lnk_up goes down. The device disappears from device manager. I have to reboot my PC.
I do trust my computer, because my old (Virtex-7) DMA engine runs stable and with high performance.
The problems are present with and Vivado 2017.4 and Vivado 2019.1
Any ideas?
Thanks for any help,
Uncle Tim
Observer uncle_tim
Re: Problems with pcie4_ucale_plus demo design - Update
A little update on my problem:
* It also present with 256 bit axi bus
* it is also caused by write transactions. I can write 1 DW but I can't write more than 1.
Uncle Tim
Observer uncle_tim
This is a short list to reproduce the error:
* Start Vivado 2019.1
* Create a project using the VCU118 board.
* Generate Ultrascale+ PCI Express Integrated Block. Everything default, just
- change device ID
- enable pipe interface (I don't thinks that matters, just for completenes)
* Open example design
* In XDC uncomment line 89 (reset pin)
* Generate bitstream for impl_1. This will be the working bitstream, for comparison
* Go to pio_tx_engine.v line 3080 and change „11'h001“ to „11'h002“ (DWORD Count)
* Create impl_2 and create a bitstream.
Install some driver so you can read from and write to the card.
In the computer software,
- Write 42 to address 0 (Or some other nice number of your choice)
- Read from address 0 → Will return 42
- Write 0xaaaa_bbbb to address 0x3aa, quickly followed by 0
  → this triggers gen_transaction for a short time
  → returns 42 on bitstream 1
  → fails on bitstream 2 because the card is no longer present
Remark1: This reads some data from fome fixed, hard coded address. This is not elegant of course, but I wanted to expose the problem with minimal changes in the demo design.
Remark2: It is important to turn on "gen_transaction" only for a short time. Otherwise the card generates too much read requests, at a faster pace than the computer can answer them. This of course leads to an error, independently from the DWORD count.
I can share my designs and drivers and test software, in case anybody cares.
Thanks for reading
Uncle Tim
