Visitor rhotheta
Re-customize IP window disabled
I'm using DMA/Bridge Subsystem for PCI Express v4.1 in my project. After creating an example project from this ip, I want to change some properties of 7 Series FPGAs Integrated Block for PCI Express v3.3. But when I open Re-customize IP window, The OK Button is disabled.
In some pages it is stated that because of IS_MANAGED property, these options is disabled. But when I want to disable IS_MANAGED property I get the following error:
Unmanage the parent source file first.
But I actually have tried to unmanage the parents too, and every time I got the same error.
Re: Re-customize IP window disabled
Hello @rhotheta,
The ability to customize a subsystem IP is documented in UG896 Appendix D in section "Editing Subsystem IP." Are you not seeing this flow work or have you tried using this flow?
Cory
Hello @rhotheta,
Cory
Visitor rhotheta
Hi @coryb
Thanks for your reply
I haven't seen that before. I'll give it a try
