Observer ajellisuk
SP604 PCIe EP demo memory locations
I'm trying to get to grips with the PCIe core example for the SP605 board. Using the demo I'm able to write a value to BAR0 from a linux app via a PCI driver.
What I'm struggling to determine is where about the value is actually stored. In the file PIO_EP_MEM.vhd I have found the following components which have been mapped:
ep_io_mem : RAMB16BWER
ep_mem32 : RAMB16BWER
ep_mem64 : RAMB16BWER
ep_mem_erom : RAMB16BWER
I have been studiny the code and ug672_S6_IntEndptBlock_PCIe.pdf, but I'm not able to determine which of the labels is actually used for BAR0. I suspect the answer is staring me in the face, and I just cant see it :)
Can someone please enlighten me as to which of the above labels is served by BAR0 and where I need to look to determin which is used.
Best regards
Andrew
Re: SP604 PCIe EP demo memory locations
Hi @ajellisuk,
This will depend on what type of BAR that BAR0 is assigned as.  If it is an IO BAR, then likely ep_io_mem, a 32-bit address BAR - then likely mem32, and so on.  It won't be erom, as that would be the Expansion ROM BAR specifically.
Hi @ajellisuk,
