Visitor ramiby
Streaming XDMA writeback problem
Shalom.
I'm Using
  • Card - VCU-118 Evaluation platform with VIVADO 2017.3
  • Host - Intel with vxWorks 6.9
I succeeded to run streaming c2h and loopback (h2c2h) in polling mode but no writing was done to the writeback address.
My driver setting:
  • 'Channel Interrupt Enable' sets to 0  (all fields)
  • Descriptor list with one element sets to 'pollmode wb addr' with 'Stop' and 'EOP' set to 1
  • Channel control with 'ie descriptor completed' and 'pollmode wb enable' set to 1
The result:
  • All the required data was copied to the Host by the XDMA
  • Channel Completed Descriptor Count is 1 as expected
  • no writing was done to the writeback address
What I missed please?
Thanks for any help.
Re: Streaming XDMA writeback problem
@ramiby
Can you read the following registers to confirm if the writeback address is set correctly?
H2C Poll Mode Low Write Back Address (0x88) -- offset 0x0088
H2C Poll Mode High Write Back Address (0x8C) -- offset 0x008C
C2H Poll Mode Low Write Back Address (0x88) -- offset 0x1088
C2H Poll Mode High Write Back Address (0x8C) -- offset 0x108C
