Observer bmjeffer2
VC709 TRD - Build failures for Vivado 2014.3
Has anyone else had trouble building the TRD for the VC709?
I'm following the steps outlined in the readme and the build starts correctly. However, I get a "Synthesis Failed" but with 0 errors on the Messages tab.
This is the last thing I see:
Start Applying XDC Timing Constraints
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'Y:/trunk/rdf0285-vc709-connectivity-trd-2014-3/v7_xt_conn_trd/hardware/vivado/runs/xt_conn_trd.runs/synth_1/hs_err_pid4344.log' for details
Bryan
Re: VC709 TRD - Build failures for Vivado 2014.3
Would that be possible to share the log?
--Hem
Observer bmjeffer2
Here's the log (not too helpful) and the .dmp.
-Bryan
Are you running the TRD in the same version of the Vivado for which it was created? Please make sure you do that. Also check the memory requirement is satisfied and your PC is not running out of memory.
Anirudh
Visitor manati
Hi Bryan,
did you find a solution for this problem?
I also ran into this error.
regards,
Maria
Visitor tiru_adrin
Hi, I am also getting the same error, I am using rdf0285-vc709-connectivity-trd-2014-3.zip, and the vivado version is 2014.3.1, and windows 7, with 32 GB memory, 1TB hard disk. I have monitored resource manager while synthesis, not even 50% mem being utilized.
I have tried it with vivado 2018.1, vivado is abruptly closing when I do source scripts/project tcl file.
Please answer as early as possible.
Thank you.
Visitor tiru_adrin
It is solved. I followed this to resolve the issue.
https://www.xilinx.com/support/answers/55687.html
Thank you.
