Observer goli12
XAPP1171 DMA to ZC706 DDR PCIe endpoint
Below is a ZC706 PCIe endpoint board design. The design is based on XAPP1171, where I have added the Zynq PS to allow DMA from a host to the endpoint DDR memory, which in this case is the PS DDR3 memory (I believe).
On the host system, I have developed the driver which is able to map the BARs. In the end, I am able to write some data to 0x00100000, which I believe is the PS DDR3 memory on the ZC706 endpoint, and retrieve the correct data from that location.
However, I have implemented some bare metal code to verify the writes to the PS DDR3 memory from the host. Reading from 0x00100000 did not yield the same value I have written from the host to the endpoint. This was done using:
Xil_In32(XPAR_PS7_DDR_0_S_AXI_BASEADDR,0x00).
XPAR_PS7_DDR_0_S_AXI_BASEADDR is set to 0x00100000 in xparameters.h.
Am I suppose to see any changes by writing to 0x00100000 from the host to PS DDR3 memory by implementing the above bare metal code? I have attached the board design and address map below, which may prove useful for answering the question.
Andrewboard design
address map
Observer goli12
Re: XAPP1171 DMA to ZC706 DDR PCIe endpoint
Given the lack of feedback on Xilinx forums, I have found that you need to enable the data and instruction cache in the SDK, then disable it after read/write to DDR memory. I'm guessing Xil_In/Out32 reads from these caches and thus it did not see an updated value as the caches were not enabled. An example of the cache code is pasted below.
Xil_ICacheEnable();
Xil_DCacheEnable();
xil_printf("writing to 0x%x\n\r",XPAR_PS7_DDR_0_S_AXI_BASEADDR);
Xil_Out32(XPAR_PS7_DDR_0_S_AXI_BASEADDR,0x1234);
xil_printf("read at 0x%x: 0x%x\n\r",XPAR_PS7_DDR_0_S_AXI_BASEADDR,Xil_In32(XPAR_PS7_DDR_0_S_AXI_BASEADDR));
Xil_DCacheDisable();
Xil_ICacheDisable();
Observer goli12
Xil_ICacheEnable();
Xil_DCacheEnable();
