Visitor kseth_xilinx
Xilinx PCIe PHY simulation in VCS
I am trying to bring up Xilinx PCIe Phy in a VCS simulation environment. I have included all relevant files and able to compile successfully but while running sims it seems because of protected/secure modules VCS is not dumping me any log or waves. On ucli run I see below message -
Warning-[UCLI-ACTIVE-SCOPE-INVISIBLE] UCLI active scope invisible
  The active scope where simulation stops in is invisible, i.e. the module of
  the active scope is fully encrypted, or one of its parent modules is
  encrypted. Moving up to its parent modules until it is visible. If its top
  module is still invisible, moving to next visible top module.
Is there any special parameter/define/vcs_switch I need to provide to get it going?
Re: Xilinx PCIe PHY simulation in VCS
Are you trying the simulation using scripts?
Can you please share the .xci file of the IP?
