Newbie lvever
error: allocating i/o bar for pci device
using core generater generating endpoint plus for pci express
and compile the example generated by the core generator
when i download bit to v5 on ml555
restart the computer
there is an err:
error allocating i/o bar for pci device
Re: error: allocating i/o bar for pci device
Did you enable a BAR to be an IO bar? If so the system may not be able to alllocate the amount of space requested. Try not using an IO bar and see if the error goes away. If it does, try requesting less space. It is recommended not to use IO bars.
-John
-John
