Observer yanghaofei@ni
get problem when using eyescan reference design
hello,
i am adding reference design for eyescan test(xapp1198) to my project to test my pcie port.
the method is:
i used the Vivado 2014.4 (which is exactly required in the User Guide and other new versions), and then downloaded source file xapp1198, navigated to the path: /xapp1198/2014.4/KC705/source/ipi_tcl, and then run the tcl file kc705_ipi.tcl in order to generate the eyescan subsystem with ip integrator.
but get the strange error below:
ERROR: [BD 5-216] VLNV <xilinx.com:ip:drp_bridge:1.0> is not supported for this version of the tools.
ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
    while executing
"create_bd_cell -type ip -vlnv xilinx.com:ip:drp_bridge:1.0 drp_bridge_0 "
    (procedure "create_hier_cell_DRP_Bridge_hier" line 55)
    invoked from within
"create_hier_cell_DRP_Bridge_hier [current_bd_instance .] DRP_Bridge_hier"
    (procedure "create_root_design" line 44)
    invoked from within
"create_root_design """
    (file "./kc705_ipi.tcl" line 512)
could someone help me please.
best regards
Advisor evgenis1
Advisor
Re: get problem when using eyescan reference design
Hi yanghaofei@ni ,
I don't think DRP bridge is part of Vivado IP repository.
There is a DRP IP core that is distributed with xapp1198 design. It requires a manual step to add it to Vivado IP search path, so that IP Integrator sees it.
Go to Project Manager -> Settings dialog. Open IP -> Repository. Click on [+]. In the opened dialog, navigate to the location of drp_bridge_ip .xci file, and click "Apply".
Hope that helps.
Evgeni
回复: get problem when using eyescan reference design
hi yanghaofei@ni
you can open IP Calalog in Vivado, search for 'drp_bridge', see the version number, for example, say 1.1
Edit the tcl file, search for 'xilinx.com:ip:drp_bridge:1.0', and replace drp_bridge:1.0 by drp_bridge:1.1
please check if this works.
Boris
Advisor evgenis1
Advisor
Hi yanghaofei@ni ,
Hope that helps.
Evgeni
it works. thank you so much.
