phy pci express ip to axi?
I have tried to use the phy pcie ip. However it only contains an mac layer and
I need an axi (lite interface). Could someone provide me with an working code
or an detailed example how to create an axi interface from this mac phy pcie?
BR
Re: phy pci express ip to axi?
phy pci express ip is generally used to interface with the fabric implementation of PCI express IP. The AXI interface is usually at the user interface of this PCI express IP.
Can you elaborate on your requirement?
The ip phy pcie have no axi interface.I want to use the ip as a endpoint to be able to write, read to eg a axi slave (bram). The ip pcie axi memory mapped have this interface but is not available for the intended chip (xzcu). How to use the ip phy pcie in pl to create an interface so it can be connected to an axi slave?
