srg1000
2019.1 : u-boot pcie device driver for Zynq Ultrascale, currently porting pcie-xilinx-nwl.c to u-boot
Currently porting the pcie-xilinx-nwl.c (2019.1)  device driver from kernel source to u-boot. Currently able to detect the PCIE bus (UP/DONW) and read sectors from attached M2 drive. However, only able to read 1 block at a time but not multiple blocks. Reading multiple blocks results in errors. Is there any note / guidance on porting this driver to u-boot? Perhaps, this effort has already been completed?
pvenugo
@srg1000 ,
I dont have reference for multiple block read and write to SSD but you can refer to simple read/write in AR# 76169: Zynq UltraScale+ MPSoC Controller for PCI Express (Vivado 2021.1) - System Example Design with ZCU102 PS-PCIe as Root Complex and Intel SSD 750 Series NVMe Device as an Endpoint (xilinx.com)
Praveen
