Visitor charleslili
7 Series FPGAs Integrated Block for PCI Express v3.3 on CMOD-A7-35T board
Hello, I am trying to use the 7 Series FPGAs Integrated Block for PCI Express v3.3 ip on my CMOD A7-35T, which has a xc7a35tcpg236-1 on it, but the ip does not show up on the ip catalog. I speculated it was because the ip does not support this part, but the device seems to meet the Minimum Device Requirements listed in the ip documentation (albeit only x2 and Gen 1). Googled around a bit and didn't find anything.
I can see the ip I want in the C:\Xilinx\Vivado\2018.3\data\ip\xilinx\pcie_7x_v3_3 directory, so I don't think it is an installation issue.
Thanks!
回复: 7 Series FPGAs Integrated Block for PCI Express v3.3 on CMOD-A7-35T board
This is a known issue with the 2018.3 this issue will be fixed in 2019.1 and you can install the patch below for 2018.3
https://www.xilinx.com/support/answers/72010.html
Visitor charleslili
Thanks!
