A pcie in-band hot reset or link disable will induce the assertion of trn_reset_n?
Hi all,
I am using Virtex6 integrated block for PCIE, the version is 1.6.
According to the user guide It seems a pcie in-band hot reset or
  link disable will induce the assertion of trn_reset_n, is it?
And how can I trigger an in-band hot reset of link disable in the pcie link?
Thank you very much for any information.
Yan
According to Xilinx product applications engineer, the in band hot reset and link disable will not induce trn_reset_n's assertion. Hope the UG517 is going to be fixed.
When you say "trigger" I'm guessing you're talking about chipscope.  I why not trigger off of trn_reset_n deasserting?
Hi, luisb
Let me clarify this problem.
Now I am not sure whether a in-band hot-reset or link disable will induce the assertion of trn_reset_n. So I want the simulate a hot reset or link disable. Could you help me to point out how to simulate them?
Thank you very much.
Hi all,
I have simulated the hot reset and link disable by control the RC config register
and the core logic signals, pl_received_hot_rst and trn_lnk_up_n, have been asserted.
But it is amazing the trn_reset_n has not been asserted in both hot reset and link disable circumstance.
Who can tell me why?
Yan
Anonymous
Not applicable
I agree that UG517 isn't clear on whether or not an in-band Hot Reset or Link Disable causes trn_reset_n to be asserted. In Table 2-10 (page 32) in the description for trn_reset_n it says that Hot Reset or Link Disable causes trn_reset_n to be asserted. However, in the "Clocking and Reset of the Integrated Block Core" section (page 184) it lists 3 conditions that cause trn_reset_n to be asserted and none of them are related to Hot Reset or Link Disable. The 3 conditions are Fundamental Reset (Cold/Warm), Core wrapper PLL losing lock, and Transceiver PLL losing lock.
Can anyone provide more info as to whether Hot Reset or Link Disable actually cause trn_reset_n to be asserted? My question is related to the 1.7 version of the Virtex-6 FPGA Integrated Block for PCI Express.
