vt.yang
AXI Memory Mapped To PCI Express (Root Complex mode) can not work for 7Z035
I am implementing PCIE Root Complex on Zynq XC7Z035 device, and the IPcore I use is AXI Memory Mapped to PCI Express. I refer to this document (https://www.xilinx.com/Attachment/Xilinx_Answer_71494_ZC706_KC705.pdf). The exact same configuration, except that I don't use PetaLinux. I use the kernel on Xilinx Github.
When my board powers up, the Linux OS stops here:
I suspect it is a problem with the address settings. This is my configuration:
This is the device tree node I generated using the Xilinx SDK:
amba_pl: amba_pl {
              #address-cells = <1>;
              #size-cells = <1>;
              compatible = "simple-bus";
              ranges ;
              axi_pcie_0: axi-pcie@50000000 {
                         #address-cells = <3>;
                         #interrupt-cells = <1>;
                         #size-cells = <2>;
                         compatible = "xlnx,axi-pcie-host-1.00.a";
                         device_type = "pci";
                         interrupt-map = <0 0 0 1 &pcie_intc 1>,
                                                   <0 0 0 2 &pcie_intc 2>,
                                                   <0 0 0 3 &pcie_intc 3>,
                                                   <0 0 0 4 &pcie_intc 4>;
                         interrupt-map-mask = <0 0 0 7>;
                         interrupt-parent = <&intc>;
                         interrupts = <0 29 4>;
                         ranges = <0x02000000 0x00000000 0x60000000 0x60000000 0x00000000 0x10000000>;
                         reg = <0x50000000 0x4000000>;
                         pcie_intc: interrupt-controller {
                                    #address-cells = <0>;
                                    interrupt-controller ;
I don't know where it was caused. Could anyone please give me some advice?
Thank you.
Tags (3)
deepeshm
Not sure what the issue is at this point. Would it be possible to try with Petalinux and see if that works or not? That would at least verify whether the issue is due to addressing or not.
vt.yang
I tried to use Petalinux to make the system, but the result was still the same, the Linux system stopped at "io scheduler cfq registered (default)".
