Visitor juli963
AXI Memory Mapped to PCIe Bus error
I'm trying to get my first PCIe design running.
I'm using a custom Board with an i.MX6 as Processor and a XC7A100T as PCIe Endpoint.
OS is Yocto.
I think it's a pretty easy first Design, I added the AXI Mem Mapped to PCIe and an AXI Bram Controller with BRAM.
My first Goal is to Write and Read data from the BRAM.
In the Address Editor I set the Offset Address of the BRAM Ctrl to 0x0 and the Range of it is 8k.
Bar0 Size is 8k and AXI-PCIe Bar Translation is 0x0.
Axi to PCIe Translation is 0x0.
constant_0 = 1
constant_1 = 0
So I think when I MMap that i should have direct Access to my BRAM without any Offset.
When I execute my Program Linux says Bus error when I start reading a address. I found out that mostly this Error Shows up when Linux is unable to read an Address. But I don't know why the adresses are unavailable.
I attached my code to Access the PCIe Device perhaps there's an Error in it?
Thanks and Best Regards,
Julian
Visitor juli963
Re: AXI Memory Mapped to PCIe Bus error
I solved my Problem with the following Command:
setpci -s "your pcie device bus number" COMMAND=0x02
I found the solution here
Best Regards,
Julian
Visitor juli963
Best Regards,
Julian
