Anonymous
Not applicable
AXI bridge PCIe IP core sys_clk and sys_clk_gt
I would like to know which clock source may I use to connect sys_clk and sys_clk_gt of an AXI bridge PCIe IP core ?
Is it possible to connect this two clock to the same 100 MHz internel clock generated from the zynq US+ mpsoc (IOPLL) ?
H.K
venkata
Please refer to Table 2-2 of PG194.
sys_clk --
UltraScale+: Dynamic reconfiguration port (DRP) Clock
and Internal System Clock (Half frequency from
sys_clk_gt frequency if PCIe Reference Clock is 250 MHz,
otherwise same frequency as sys_clk_gt frequency).
Should be driven by the ODIV2 port of reference clock
IBUFDS_GTE4.
sys_clk_gt --
UltraScale+: Should be driven from the O port of
reference clock IBUFDS_GTE4.
venkata
sys_clk is required to be driven from an oscillator from the board (or) slot clock coming from Root Port. Do you have any of these options with your design?
Anonymous
Not applicable
I use a clock (IOPLL) driven from the PS part of zynq ultrascale+
venkata
IOPLL from PS cannot be used to source sysclk of PCIe.
Anonymous
Not applicable
what about clk_gt ? can I use IOPLL from PS ?
venkata
sys_clk --
IBUFDS_GTE4.
sys_clk_gt --
