AXI-to-PCIe reads all FF's from BAR 1
Hi all,
I can't seem to read anything but FF's from PCIe BAR1 address space when using the IP block for the AXI4-to-PCIe interface.  My hardware works fine with an older 2016 .bit file, so I know my problem is in Vivado 2019 or my VHDL code.   Please see attached PDF file for more-detailed information and screenshots.
Thanks in-advance for any advice you can offer !!
Hope you are surviving the COVID-19 pandemic so far
Erik
Tags (3)
Hi all,
after more wrestling with the configuration settings of the AXI4-to-PCIe IP block, I was able to solve my own problem in my design.  The solution required throwing out the auto-assigned addresses that the silly "Address Editor" had automatically assigned to my BAR1 slaves, and manually entering sane values for the start address of each BAR1 slave myself.  Once I had decent addresses near the bottom of the BAR1 address range (instead of the auto-generated ones at strange offset values) I could read them just fine.  See attached screenshot.
Thanks for those who viewed my issue and gave it any thought at all
Erik
Hi all,
Erik
