Observer goli12
Access to custom IP core on ZC706 PCIe endpoint from host
Below is a ZC706 PCIe endpoint board design. I have attached a slave AXI port to the PS and I was wondering if the host would have access to IP block? I have also included the address map of the system.
Cheers
board design
address
Observer goli12
Re: Access to custom IP core on ZC706 PCIe endpoint from host
I have found that for the host to see the IP, it needs to be the slave of the CDMA core and the PS. The CDMA cannot access to the IP as it is not a master of it.
Observer goli12
I should also say that the design is based on XAPP1171
Observer goli12
