Artix 7: Choice of PCIe IP
We would like to send a video stream through a PCIe interface with an Artix. Xilinx seems to have 2x different IPs:
- NWL PCIe DMA (https://www.xilinx.com/support/answers/62804.html) provided with the AC701 kit (the example seems to be quit big in term of LUTs).
- DMA/Bridge Subsystem for PCI Express
Which one should be the best for video application? We need about 500MB/s.
The main issue is the Linux driver: it would be the best to have a Video4Linux driver. Any other option with this kind of driver?
Denis Alain, Eng.
Tags (3)
Hi @dalain00
We do not provide or have control over the NWL PCIe DMA IP, this is provided by North West Logic and is a soft IP. It was used with this kit to show some functionality but as it is a soft IP and so it will use a lot of resources compared to the Xilinx DMA/Bridge Subsystem for PCI Express (XDMA) which is a hard block IP.
Please see the XDMA product guide PG195 for more information. We also provide drivers for Windows and Linux in AR:65444 and this can be used as a starting point to show functionality for the XDMA.
https://www.xilinx.com/support/answers/65444.html
Kind regards,
Gareth
Hi @dalain00
Kind regards,
Gareth
Thanks for the info. We will look at the XDMA more closely with our application in mind.
Best Regards,
Denis Alain, Eng
If you are able to get XDMA working on the AC701 please let me know! I have been struggling to get the card to be recognized on Windows.
Here are my struggles and what I've tried so far: https://forums.xilinx.com/t5/PCIe-and-CPM/AC701-PCIe-Example-Design-Problems/td-p/1075343
I'd really appreciate any help regarding the IP configuration and XDC constraints if you get an example design running (even on Linux).
Best,
Brad
Hi Brad,
We are still defining the project, but if I have a chance to try the XDMA successfully, I will certainly help you if I can.
Best Regards,
Denis Alain, Eng
