lkantoski
Atrix 7 - Integrated Block for PCI Express v3.3 Timing Violations
I am trying to build project using the PCI Express IP core and have been seeing various setup time violation related to signals within ip core.
Here is a couple of the signals failing timing:
RTD_PCIe_Interface_i/U0/inst/pcie_top_i/axi_basic_top_i/rx_inst/rx_null_gen_inst/reg_pkt_len_counter_reg[4]/C
To:
RTD_PCIe_Interface_i/U0/inst/pcie_top_i/axi_basic_top_i/rx_inst/rx_pipeline_inst/reg_tlast_reg/D
To:
RTD_PCIe_Interface_i/U0/inst/pcie_top_i/axi_basic_top_i/rx_inst/rx_pipeline_inst/trn_rdst_rdy_xhdl4_reg/D
I have seen these off and on between Vivado 2017.1 through 2017.4.
I also see similar violations with the example IP design. I have attached the example IP design that sees the violations. The project was generated in 2017.4.
venkata
I could reproduce the timing violations using your project. I find that the same project is closing timing with the next vivado release (2018.1).
venkata
