BMD project support interrupt ?
Hello:
     I have been doing DMA work of Pcie with XIlinx BMD project Demo. For interrupt, i have duzzle for it. Can anyone help me ?
1、 Does BMD project Demo  suported leagcy interrupt?
   The logic of cfg_interrupt_rdy_n and cfg_interrupt_n in BMD_INTR_CTRL.v of BMD project  is  conflicting with  file describled in UG341.pdf.  Can anyone tell me which is correct ?
Actually, in Hardware test, I can get cfg_interrupt_rdy_n and cfg_interrupt_n signal time-relation with Chipscope. Please see picture(1) !
But I can not get this leagcy interrupt in my  Deiver tool (Windriver), meantime, the PCI STATUS register bit[3] is '0' at all times. So Is this leagcy interrupt really  transmitted by FPGA ?
2、 Does BMD project Demo  suported MSI interrupt?
  If supported, so MSI should transmitt  interrupt with Memory write request!   But in BMD project, MSI MWR logic is not existent. Is this correct?
THANKS!
Message Edited by pzczly on 10-28-2009 05:59 PM
Hello:
  In UG431.pdf,  file states that cfg_status[3] does not reflect the state of peding interrupt in the device/function !    But,  PCI specification  states cfg_status[3] is used to indicate
pending interrupt !   So, is this why ?
If I agree with UG341.pdf,  then now  How I jude leagcy interrupt in WinDriver ?   Because I can not jude interrupt through this cfg_status[3] register !
There is some disappointing info in this thread:
http://forums.xilinx.com/xlnx/board/message?board.id=PCIe&thread.id=295
Thank you for Nreasoner!
Now, i'm duzzled!     Can anyone tell me if  BMD_project(based on xapp1052) support interrupt?
if supported, then  I send cfg_interrupt_n, cfg_interrupt_rdy_n,cfg_interrupt_assert_n which based on ug341.pdf.   Can PC system get INTA#  through configuration status register[3] ?
With legacy interrupts enabled, the pcie core has to first send an interrupt with "cfg_interrupt_assert_n" asserted, and then send another interrupt with "cfg_interrupt_assert_n" de-asserted.
We found that the core wasn't sending a de-assert interrupt, because the driver has to initiate this by setting the LEGACYCLR bit in BMD Register # 18 :
            // 48-4BH : Reg # 18
            // INTDI (RW)
            // INTDO
            // MMEN
            // MSIEN
            7'b010010: begin
               if (wr_en_i) begin
                  INTDI[7:0] <= wr_d_i[7:0];
                  LEGACYCLR <= wr_d_i[8];
               end
               rd_d_o <= {4'h0,
                          cfg_interrupt_msienable,
                          cfg_interrupt_mmenable[2:0],
                          cfg_interrupt_do[7:0],
                          7'h0,
                          LEGACYCLR,
                          INTDI[7:0]};
            end
The interrupts worked once the driver was modified to do this.
