Teacher rcingham
Bad 'pcie_blk_plus_ll_rx.v' file (PCIe endpoint v1.13)
FPGA: Virtex-5 FX100T
CoreGen: 11.4
IP: Endpoint Block Plus for PCI Express, v1.13
ISE: 14.2
The 'pcie_blk_plus_ll_rx.v' file that is generated does not compile.
The first error message is about an undefined macro, TCQ.
Teacher rcingham
Re: Bad 'pcie_blk_plus_ll_rx.v' file (PCIe endpoint v1.13)
I note that the file generated by the v1.14 tool has the macro definition in it.
Teacher rcingham
The workaround is to copy the macro definition
`ifndef TCQ
 `define TCQ 1
`endif
 from 'pcie_blk_plus_ll_tx.v', or one of the other files that defines it identically.
The error is with ISE PN working out its own compilation order, but I don't know enough Verilog to understand the subtleties of macro definition...
Teacher rcingham
