darin_i
Block automation fails in Vivado 2018.2
I'm following the instructions given in PG195 (04-04-2018) for generating the IPI example design and it fails with the following cryptic message:
apply_bd_automation -rule xilinx.com:bd_rule:xdma -config { accel {1} auto_level {Subsystem Level} axi_clk {Maximum Data Width} axi_intf {AXI Memory Mapped} bar_size {Disable} bypass_size {Disable} c2h {2} cache_size {32k} h2c {2} lane_width {X1} link_speed {5.0 GT/s (PCIe Gen 2)}}  [get_bd_cells xdma_0]
missing operator at _@_
in expression "...ne eq "X8") && ($link _@_$LS_5_GTS "
ERROR: [#UNDEF] Error found in procedure apply_rule.
report_ip_status claims everything is up-to-date.
Anyone come across this before?
darin_i
Hi Cory,
It is not a Xilinx board, if that's what you're asking. It's a carrier board sold by a third party. I will work around the issue (if I continue using this board to be honest). The board manufacturer has stated they will repair their board files to be compatible with IPI.
darin_i
Replying to my own post :-)
I read back through the example in PG195 and thought "let me  try an older rev of Vivado"
I tried the same thing in 2017.4... same result.
darin_i
Solved it.
Problems in the board definition data hosed the block automation process.
coryb
Hello @darin_i,
Are you using a custom board file or a provided board file i.e. KCU105, etc. Also what did you change the resolve the issue?
Cory
darin_i
Hi Cory,
