yonigo
Bus Master for vc709 PCIe3
Is there an example design of a bus master (dma engine) that works with the vc709 gen3 core?
kotir
Have a look at the below links.
http://www.xilinx.com/support/documentation/boards_and_kits/vc709/2014_3/ug962-v7-vc709-xt-connectivity-trd-ug.pdf
http://www.xilinx.com/support/documentation/boards_and_kits/vc709/2014_3/rdf0285-vc709-connectivity-trd-2014-3.zip
KR
