Can I insert my XtremeDSP Virtex 4 kit card into pci-e ?
Dear all,
I have a XtremeDSP Virtex 4 kit card which should be used for a pci slot.
But nowaways, most of pc have pci-express standrads.
May I know if anyone has encountered the same problem and fixed it before ?
Thanx~
If you are asking can a PCI card be plugged directly into a PCIe slot, then the answer is no.
You might want to google"PCI Express to PCI Bridge Card" and see if you can find some type of adapter solution.
-John
-John
Dear Jayer,
I think my XtremeDSP Kit with Virtex 4 has PCI-X pins.
However, I searched all doccuments I can not find out what kind of PCI-X it is.
May I know
1) how I can find out if the XtremeDSP Development Kit with Virtex 4 has PCI-X 1.0 or PCI-X 2.0 or PCI 64?
2) There are two ADC and DCA channels on the kit. Each channel can operate up to 105MHz. If I operate two channels simutaneously, does it mean each channel get 53MHz or still 105Mhz indepentaly ?
3) If it is PCI 64 which can operate up to 66Hz, doesn't it mean some bandwidth will be scarcrified ?
Thank you very much~
Sincerely,
Xilinxgirl
Hi all!
I'm using xtremedsp development kit virtex 4. I have a problem with it while co-simulation. when I run the program it requires the firmware v2.2 but when I search on the net, I can't find it. Can anyone help me download firmware v2.2? and How to update it for kit?????????? thanks in advance!
Hien
