Clock for usr_irq_ack
It is stated in  document for DMA/Bridge Susbsystem for PCIe ( https://www.xilinx.com/support/documentation/ip_documentation/xdma/v4_0/pg195-pcie-dma.pdf ) that
what is the clock frequency that needs to used to detect this positive transition of usr_irq_ack, so that usr_irq_req can de-asserted ?
in other words, what is the clock period used in the above diagram ?
Re: Clock for usr_irq_ack
You can use axi_aclk output to capture usr_irq_ack output.
@venkata
Thanks a lot
