Connect Each Endpoint to Each Pcie Lane
I am developing custom board with zynq 7030. I want to connect 4 pcie endpoint device to integrated pcie block(zynq is root complex) directly(without any pcie switch)
Can I create multi Pcie bridge in root complex or how can I connect endpoints to one root complex.
Thanks four your reply.
Hi @yamak
I believe this is a duplicate post to the one below which I have responded to.
https://forums.xilinx.com/t5/PCIe-and-CPM/Does-7-Series-Integrated-Block-for-PCI-Express-Core-Support/m-p/1110703/highlight/true#M16550
Response from above post:
No, we do not support multi port Root Port and I have not heard of this. Is this something you have seen in the specification?
Kind regards,
Gareth
Does anyone have any idea about this issue?
Hi @yamak
Kind regards,
Gareth
