[DMA+AXI] Question
I'm configuring the DMA Subsystem for PCI Express for a Virtex UltraScale+ fpga. What I want is to send requests (read/write) from a host (PC) to the fpga. I'm a rookie and I have a strange doubt.
When I create the module the ports of the instance are for a master, that is, I want that DMA to be a slave that will receive requests and I will perform that requests with my verilog code. What should I do to configure it in that way? Should I activate AXI4-Lite Slave?
I have another module for DDR4 IP where I use AXI too and I'm the master so I know more or less how it works for the master case, but as a slave the DMA should have inputs about read address and read data, and in this case they're outputs.
Maybe I started configuring it wrong and I need to set as AXI Stream and not as AXI Memory Mapped? Or should I use AXI Bridge for my purpose? I'm a little bit lost in that.
Also, would be nice to know how can I send interruptions to the host. But for this last question maybe the response is in the documentation which I'm reading step by step.
My last question is about
I don't know if I'm explaining well.
Re: [DMA+AXI] Question
Can you please go through the quick take video at the link below?
https://www.xilinx.com/products/intellectual-property/pcie-dma.html
This can help you to get the basic understanding of how DMA transfer works.
After this, please try a simulation of IP example design to understand the process.
