Observer petersanch
DMA PCIE Causes Computer To Blue screen
I have a block design for my AC701 board trying to use the DMA/Bridge PCIE block.
xdma_info.exe shows theres a PCIE device connected. When I try to run xdma_rw.exe or xdma_test.exe the computer shows a blue screen and stops. This is the message. I need to turn off and turn on the computer every time.
"Hardware malfunction. call your hardware vendor for support. Parity check/memory parity error. They system has halted".
Whats the cause of this?
Cheers
Observer petersanch
Re: DMA PCIE Causes Computer To Blue screen
Changed os to linux and it works now. Maybe problem with the Xilinx win drivers?
Observer petersanch
Update:
Im able to get ff ff ff ff when I run xdma_rw.exe user read 0 – l 4.
If I try xdma_rw.exe user read 0 – l 8, then the system gets blue screen. I tried this 3 times and the same thing happens.
Is reading more bytes than 4 causing this? Is it possible that the command is reading a read protected address of some kind?
Observer petersanch
Visitor wjin
Probably it's a bug in Windows version of driver.
WdfMemoryCopyFromBuffer() was used in ReadBarToRequest() and WriteBarFromRequest() to transfer data to and from the mapped memory.  Replace it with READ_REGISTER_BUFFER_ULONG() and WRITE_REGISTER_BUFFER_ULONG() correspondingly should solve the problem.
hi,
wjin, can you please elaborate on the solution for window 10 ?
( "WdfMemoryCopyFromBuffer() was used in ReadBarToRequest() and WriteBarFromRequest() to transfer data to and from the mapped memory.  Replace it with READ_REGISTER_BUFFER_ULONG() and WRITE_REGISTER_BUFFER_ULONG() correspondingly should solve the problem." )
thnaks !
moshe
